Thanks for clicking on the post. I have a 2004.5 2500 QC 4x4 5.9 6speed. 58,000ish original miles. I'm the original owner. I run 295/70-17 tires with a 2" KORE lift. The current issue which is getting worse by the mile is a vibration in the floorboard. It started to be noticeable at Hwy speeds while coasting and would go away under acceleration. It progressed to slower speeds, still coasting. Now 80 miles later, the vibration is very noticeable under breaking also. The truck does not pull right or left. There is not a sound to go along with the vibration. I just jacked it up and spun the wheels by hand....seemed fine. I grabbed the wheels and could not detected any abnormal movement that would point to a wheel bearing failure. I grabbed the front driveshaft and it seemed fine. This truck is a "seldom" daily driver and had not been "stored" for long periods. The tires are new-ish (1500 miles). Any thoughts or suggestions would be great. At this point I don't think it's safe for the Hwy.
