2005 Alfa See Ya 5th Wheel Model 315 - $23000
89 W350 Regular Cab 12 valve
10 lug adapters and lift kit
We purchased this RV new. We are not smokers. We've had no pets in the RV. We have never rented it out. We purchased it because of Alfa's 'innovative changes' to the 5th wheels. For instance, their dual A/C's under the RV similar to their Class A's (instead of on top - better cooling). In addition to their large storage areas like a Class A, it has King size bed, ample storage and kitchen layout. It is capable of adding washer/dryer and adding a generator, has tall shower, many extra's. This was a $68,000 RV when new. We've traveled only to Orlando, Grove, OK, Red River, NM, and Colorado Springs. With the kids grown and not using it very much, we have no use for it anymore. Currently, we have less than 5 years on a loan with a nationwide bank. I can pay off the note if you want a clear title. If you want to take over the loan, you can get approval with the bank (used RV's are hard to get loans for, so I thought this would be a convenient option for some). Other than a few trips, it has been stored under a covered shelter. We have never used the stove or awnings (technically it has the side awning and the front 'cap' can be opened, which counts as an awning). We used the refrigerator once. This RV has been used very little and is in great shape. RV is currently winterized and all systems function properly. This Alfa is out of warranty and is sold as is. Parts are still readily available from the Aflateers group (I can provide there contact info) in California. For Sale Locally, auction can end early. If you have any interest in a 2013 Ram 3500 that I used to pull this RV, I will be listing it for sale shortly. Please contact me if you have any questions. Here is some info from the Alfa See Ya brochure:
It has 8' ceilings throughout main living area. 32" HD Flatscreen TV with remote in living room. Living room and master bedroom slide out. Sofa with hide away bed. Leather Euro-recliners with foot stools. Large panoramic windows even the bedroom. Mini-blinds. Dinette table with 4 upholstered chairs. Wired with multiple telephone jacks. 2 TV jacks. Pre-wired for solar panels. R-11 Sidewalls insulation. R-20 Roof and Floor insulation. Front opening picture frames allow you to add your own pictures. Residential style basement heating and air conditioning system using common floor ducting. Designer 42" ceiling fan. Armstrong Ultra-Durable flooring. Spacious solid surface galley countertops. Alfa Exclusive interior/exterior trash can system. Convenient single lever faucet. 21" oven with 3 burner range with high output burners. 1.2 CU. FT. microwave oven. Up to 16 CU. FT. refrigerator/freezer with ice maker. Master bedroom "Magic Bed" lifts up in for storage and slide-out operation. Vacuum bonded bed/bath floor. Large residential style closet with mirrored wardrobe doors. Solid privacy doors. Directional reading lights at bed. Air dam headboard. Up to 6'6" headroom in bed and bath area. Deluxe inner spring ultra-firm soft top mattress. Color coordinated bedspread/comforter, shams and valances. Frosted window in toilet room. Large fiberglass shower enclosure. Hi-Dome dual pane skylight with sunshade (up to 6'6" headroom). Large mirrored medicine cabinet. 12 volt power exhaust fan. Towel bar. 19" bedroom TV. Solid surface countertops. Abundant bed and bath storage. Main Living Area has Dolby digital 5.1 DVD/CD/MP3 home theater system with surround sound. Entire coach is pre-wired for satellite dish and high quality RG-6 coaxial cable. The exterior is welded aluminum framed 2 3/8" thick walls. SpaceMasterII (tm) chassis puts tanks over trunk. Steel 21" main rail chassis design. Massive trunk storage compartment. New-View front awing and window. Three 5-gallon LP tanks for easy exchange. Slide-out step system. Interlocking roof and sidewall floors using space age epoxy. Ultra light high density composite roof with EPDM(tm) rubber. Enclosed underbelly (galvanized metal). Enclosed holding tanks. One-piece fiberglass rear cap. Tinted safety glass windows filter 87% of UV rays. Large entry-assist handle. Roll-out patio awning. Outside security and convenience lighting. 10 Gallon DSI water heater with switch. Water heater bypass system. Black water tank flush system. TV antenna (UHF, VHF) with power booster, cable TV ready. Computer balanced radial tires with spare. Jack leg pins. 100 Gallon fresh water tank capacity. 116 Gallon gray water tank capacities. 55 Gallon black water tank capacity. Four batteries.
http://oklahomacity.craigslist.org/rvs/5618239060.html
You can view the Alfa See Ya Manual from the internet. http://library.rvusa.com/brochure/2005_Alfa_See Ya.pdf
