GrantP
Need some help here guys. Truck was running fine this morning and has been mostly trouble free for the time I've owned it. I loaded up the family in it this morning and it started and ran for 2 or 3 seconds and died. Tried again, same thing. Rail pressure would come up to 7k where it's always been at idle when it was running. After the 5th try it won't start at all. I have not had any hint of any problems prior to this, it has always run great.
To be clear it turns over fine but doesn't run.
I have no codes. The engine is bone stock, no tuner ever.
I changed both fuel filters thinking it was a fuel supply issue. Both filters were completely unremarkable and clean enough to probably reuse but I changed them anyway. The fuel I drained looked clean. Did the bump of the starter to prime the system and the factory in tank fuel pump filled up both filters so it is working. Fuel level is 1/4 tank so I would think if it was bad fuel on the last fill that would've shown up a long time ago.
Could a bad FCA do this? Wouldn't it throw a code? I'm at a total loss here. Thanks in advance.
