I have a 2006 dodg ram 2500 5.9 diesel my ac worked until last year i sucked the system out put new drier on and recharged still didnt work compressor is not engaging the presure is right and the pressure switch is good i put my snap on tool on it and it keeps loosing communication with the ac system i tried new switches in the dash but can not get power down to the compressor only code in ac system is for the temp sensor in heater box so it dont freeze up tried jumping senor and does not show no difference on my scan tool my buddys truck when unplug that sensor says open and if u jump it says 100 degrees mine shows no difference no matter what you do to it i did some reading some say pcm but when i look up pcm i get pcm/ecm/ecu is all one and i dont want to spend that much money and not know the problem if anyone has and input i would appreciate it. Thanks
