2007 6.7 Ram 2500 DTC Help (ETC Level 2 RPM Performance & Gen voltage sensor high)
Snubber valve yes or no
07.5 2500 6.7 Code P2563
Hello all,
As the title says, I am getting the P063D (Generator Voltage Sense High) and P061C (ETC Level 2 RPM Performance) DTC's.
The truck has 149,000 miles on it and sits in my garage when I am out of town, sometimes months at a time.
Before leaving to go out of town this last time the truck dinged and the OHD said "Perform Service, See Dealer Now". The truck is fully deleted, (except for the CCV filter so I figured that since it has been about 50,000 miles since the last ccv filter change then that must be why its freaking out. I went out of town and ordered the filter & installed it when I got home. To my surprise, the old filter wasn't bad at all. So I got in the truck and fired it up and the damned message was still there. The truck runs flawlessly, but I called my local ram dealer and the tech said that it must be because I am deleted. After informing him that I have been deleted since 22000 miles he still insisted that it must be the problem. The OHD will not allow me to delete the message, as the message only appears after the truck is running.
Fast forward about 8,000 miles I had a front left ABS wheel speed sensor go out. I replaced it and all the aforementioned messages went away..
drove the truck about 300 miles to a job site, drove around all day, then I started it and let it high idle for an hour to allow it to cool off before getting in. When I was leaving I got on it pretty hard to get on the highway and then BAM "Perform Service, See Dealer Now" pops up, this time with codes, but no CEL and no other lights on the dash.
My trucks charging system is just as it always has been, 14 volts so i do not foresee there being an issue with the charging system. Im using an edge insight for monitoring vehicle.
What do you guys think is going on? I'm growing tired of dumping money into this thing. Its seen more mechanics shops than anything now days.
