2013 Ram 2500 Limited
Dually fenders
Gearvendor OD Unit for G56 4x4 - Needs Rebuild
I have a 2013 Ram 2500 Crew cab short bed, 6.7 Cummins, 6 speed Auto, "Limited" edition trim package, truck for sale. It currently has 40,000 miles on the odometer. Still have a factory warranty remaining. There is a spray in bed liner. It does have the "RamBox" option. I just replaced every single fluid and every filter as part of the 45,000 mile recommended service. I like to keep ahead on maintenance. It is all documented. This truck is the first year of DEF emissions. Honestly it blows away my 2011 I had prior. There are a few items I have installed after market. The truck has a set of Amp-Research power steps ($1200), I installed a ez-drain Fumoto oil valve ($30), Dura-Flap mud flaps ($200), upgraded the headlights to 35w 5000k HID Morimoto brand ($150), and also added a fuel cap ($30). Asking $45,500. Can help with delivery as well.
Do you have a picture of the odometer corporate shows the mileage at a higher number when your last recall was performed?
Ubersox Chrysler in Platteville, WI was the dealer that made this error. They entered 52,xxx miles instead of 32,xxx miles (i can't recall the exact values). I had my local dealer (Bergstrom Ram of Oshkosh, WI) try to contact corporate and correct it. Apparently they never did. I can get a picture of the odometer if you are interested, or perhaps you are just trying to point this out? The CarFax was messed up as well, however that has been fixed.
Dealer entered ong mileage on my c5 corvette. Carmax said,WARNING...ODOMETER DISCREPENCY.... I did straighten it out showing maint. Records....
That was exactly what the original CarFax said before I had it fixed. I just hope Corp. will fix it on their records now.
No, however I will be trading it with the month (truck is suppose to arrive). So I guess it is still for sale. Thanks for your interest.
