Perform Service light
Transmission code
2013 engine improvements
A quick update on some new features
New crank damper
New camshaft with revise intake lobe profiles
New injectors and no need to enter correction codes
Smaller diameter water pump pulley to increase flow rate
revised pistons new bowl design and smaller diameter skirts that have been graphite coated in pick-ups
both c/c and p/up pistons get upper ring gap change for improved sealing
New cooling nozzles
New bedplate that reduces nvh plus acts as windage tray
new flexplates for the aisin equipped trucks
new dual branch exhuast manifold
Dual inlet system for intake air
Turbo actuater has higher torque and will be flash reprgramable and replaceable
Up to 75 second time for grid heaters
4micron frame mounted fuel filter/water separator with wif sensor
3micron engine mounted filter/water separator with hydrophobic screen to aid water stripping
engine filter must be installed or will not start or run
Fuel filter change warning will be added to evic
pick-ups rated to operate up to 20% bio
C/C must be ordered be ordered with sales code xxj to run 20% bio
Might have missed something but sounds awesome for next year.
75sec grid heater? wow, was that supposed to be 7. 5?? I read something about the 3500 850ftlb torques engines running the Asain transmissions, do you know of that's true or if they will still run the 68RFE?
It's about time!!!
Thanks for the update... . any idea on the damper has changed again?? heavier, larger??
