2020 tsb
Any CP3 issues on 6.7?
Extended warranty for used 2017
There appears to be three. 18-048-20 Rev A PCM flash, 18-060-20 CP4 pump identification, 23-016-20 5th wheel/Gooseneck hitch fit.
Sag2,What would CP4 pump identification do/be for?
It's a bulletin, not a TSB. See att
John the Tsb is for the techs in the field to be able to recognize the new style injection pump has been installed.It requires a different software to operate than the the original pump
So now that I have the " Oh no, is my Injection pump gonna go out" worry, which one of these is the "good one" and how do I find out which one I have??
Looking at the pump just below and to the rear of the uppermost pumping cylinder, the housing will have a single dot machined into the case for the updated pump. All the other pumps can have multiple dots in that location.
It seemed to say this programing for this pump and this programing for that pump or you will hear noise . It didn't say anything about one being a POS and the other is a Technological wonder pump quit worrying that yours is going to break . Everything breaks if you keep it long enough . Just drive it !
