Well my T-case leak isnt gettting any better or healing on its own. Fill everyone in from my last post, T-case is leaking from front output or driveshaft. I first checked to see if it was overfilled, it was, let it drain out the fill hole. It did slow the leak a little. I tried removing the front driveshaft, but I couldnt get the 4 bolts out of CV joint flange. Got the nuts and lock washers off, but not the bolts where CVJ meets T-case flange. This is where its leaking as you can see in the pic. I've heard a synthetic will make a small leak a big leak, so I've thought about changing the Mobil 1 syn 75-90, has been in for a year, to a conventional gear oil. If you look close at pic, on the bottom bolt is a drop of oil. Any help fixing this leak will be appreciated. Bill
