The 215 nozzles can be put in the right holders with parts changes. However, they do not result in any performance increase.
I would suggest them, but only if you were at very high atitude ( above 5000 feet) all the time, because of thier excellent smoke control characteristics.
However, there's no reason to use them for anything else. The holders the nozzles come in orginally will NOT work in your truck, as the high pressure c onnector is wrong. There are also changes inside and the pressure is set higher than the original injectors.
