Engine/Transmission (1994 - 1998) 215Hp injectors can they be improved
Engine/Transmission (1994 - 1998) timing in michigan
2nd Gen Non-Engine/Transmission need a/c specs for pressures
I just installed a set of DDP stage 2, but I am wondering if DDP could take my 215's rebuild them to let say a set of Stage 3' or stage 4's or would this be worth doing?
All the injectors can use different tips. 160/175/180/215, etc. You can use 370 tips, anything you want. Mine are actually 160's with EDM 370 tips.
You can even use 1st gen bodies with 2nd gen tips, and vice-versa.
--Jeff
