22.5 Rims on 2500
Re-Mapping Controller
Headlight Relay Wiring
Ok, I have seen a 1 ton SRW crew cab Ford diesel with 12 inches of lift and 22. 5 rims. Has anyone done this with their ram or know where to get rims such as these?
Wow as a matter of fact
There was a ram floatin' arround with what would appear to be 22. 5's on it and I think they were alcoa's M/T Series. The reason why that stuck in my mind was the fact the tires themselves looked like "low Profile" tires. Pretty cool too if I might add. But this can only be an ON Road Ram from that point on in as the bead of the rim is so vulnerable to serious dingin' and bending off road. <hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Powerpack By Bank's (4 inch exhaust,High ram intake,wastgate mod to 38 psi,ottomind TLC +guages,K&N) ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec'sDouble Deep Trans pan,DD injectors+Van Aken+Autometer Guages. Check out Tool's Stuff#ad
N. E. T. D. P
Here is a place out of Texas that has them for the dullies. I dont know what you would need for the 2500's. The only pic I saw of a ram with 22. 5's on them was on this site. I personally thought they looked entirely disapportiant to the size of the vehicle. I would however like to see some more pics though.
http://www.chromewheel.com/dominator.htm
Holy Cow! Look at those on the black Cummins 3500..... they are just a little too big for my taste. I'd stick with the 19. 5's
