Engine/Transmission (1998.5 - 2002) 234,112 codes, limp mode
234,122 codes, limp mode
99, 2500, LB,5 speed, 3. 54 with service body, 8500# normal weight. I have been having 234,236 and now 122 codes come up. When the temp gets up to almost normal,160, it goes into what i think is limp mode. I runs, but won't hardly get out of it's own way. I have a temporary boost guage connected and the waste gate works as it should, opens 17-19 psi. I think i may have a bad boost sensor. And, the 112 code just came up today. anyone have similar problems and what was solution? thanks
P0112 - Intake Air Temp Sensor Voltage Too Low
P0234 - Turbo Boost Limit Exceeded
P0236 - MAP Sensor Too High Too Long
If you're not running a box and boost fooler, I'd say that you're wastegate stuck closed at some time and caused the 234 and 236. The 112 looks like it might be a bad IAT sensor. You can pull it out and clean it to see if that helps. You can find the resistance values in an old post on here about IATs.
Thanks for the reply. I mistakenly said 112, and it is 122, tp sensor, and i have had a gage on it when it said 234 and there was never anything over 18. 5 psi. This is a stock truck with only 4"turbo back magnaflow exhaust and K&N air cleaner. I have a code reader and can erase the codes, and have, to check if something I try does any good. So far nothing has changed. The 122 is a new one to come up.
