Any one with a P1700 Pump on a 01, 24 valve
on the 01 truck I would like to swap vp44 to a 180 to 215 P Pump
If I understand this,correct I need to change the pump timing case & cover
pump drive gear & maybe the cam gear.
will the cam have to come out, I think it is a press fit
could i drill & tap three holes in the cam gear & use a puller with a little heat to remove the gear from the cam in place & use a little heat to put the gear
back on. will the other gears come out OK to get the timming case out.
I understand I will need special injectors & lines is this correct.
If so where do I find them. I would like to use as many stock parts sa possible
I have the case pump on hand. we are not talking about cost.
I would like to here from people who has done the converison
How did it come out power & milage wise.
The engine will be comptely Mechanical Is this correct
Did I miss anything.
