The manual calls for (Schedule A or normal):
Oil/Filter change 7,500 miles.
Valve adjustment 150,000 miles
Fuel filter 15,000 miles.
Rear brake adjust at each oil change.
transmission fluid/Filter 30,000 miles.
Coolant replace at 30,000 or 36 months.
Thansfer Cace drain/refill 90,000 Miles.
These are all great ... . but what have Other owners in the "Real World" seen and suggest.
Myself, I change Oil/Filter (fleetgaurd LF3552) at 3,000 regaurdless of what the manual says. . I Believe in the saying of "The cost of an oil change is the cheapest Mechanic you'll ever have. "
I change fuel filters at the 15,000 and only buy fuel at well used stations with good reputations.
I have done 2 transmission fluid/ filter changes so far . . (24,000 Miles on the truck so far) the first was done at 5,000 miles to get the "Factory Fluid" out of the case, and the next about 500 Miles ago. . (you can't drain the torque converter and a lot of "Old" fluid stays behind.
If there is one thing I have learned it's that if our Dodge trucks have one weak spot it would be the Automatic transmission... Just go to your local dodge dealer and sneak a peek into the service bays. Buy the service Manager or better yet, the Write Up man a soda or coffee and ask him how often he REALLY sees transmission work in the shop. . I think you will be suprised... SHOCKED... STUNNED...
Warrantee or not . . I want my truck in the driveway and not up on a lift. The cost of 4 gals. of ATF +3 was only 26. 00 or there about. It may not be the "Magic Bullet" but It will help.
Now that I have a Drainable transmission pan I can change fluid often and filters every other fluid change.
I have Coolant on order with my local Cummins / Fleetgaurd dealer and will be putting draining/refilling from now on using the 1/2 now 1/2 later principal discussed in TDR this issue. . (Thanks guys... Never would have dawned on me to do it that way. . EASYYYYY. )
Rear Diferential will be done before the winter sets in... (actually I'm saving my Pennies for the Mag-Hytech Diff. Cover so I can kill 2 birds with one stone).
Front differential will be done next spring. . after winter 4WD use.
I know most of the people reading my maintainance routine will think it's overkill and it most likely is.
However, I made a significant outlay of cash for this beauty.
I am Kinda Obsessive/Compulsive to begin with . . but it's better to spend the time and Money this way than to spend all my free time in front of the tube of at the local watering hole. Besides My wife now knows EXACTLY where I am at all times... And She is happy with that.
Larry Quinn
98. 5 24V 2500 SLT Clubcab.
Lot's of factory and aftermarket Toys. . but not Cheesy...
