Hello I'm trying to connect to the return lines on the back of the motor with a "T" to combine the return from my Mallory bypass regulator. Now the problem, I can't seem to find out about the fittings that are used on the lines. The "T" that's on the hard line looks like a parker fitting ( it has a P cast in it) but, I can't seem to find that style of fittings on the parker web site. The site lists every other type of fitting known to man, but not the style used on the truck:-( BTW this is on a 98. 5 motor in case they changed the setup on later models.
Thanks
William.....
Thanks
William.....
