Details here: TDR Privileges
NAPA can get you the correct seal. Also some of the Tcases have a double row ball bearing on the input. While you are at it check out the snap ring on the output shaft especially if you have a single piece driveshaft. There is an after market collar called Transfer case saver that you can use to replace the snap ring if you like.
go to carquest and ask for seal #22029 that will probably do the job my transfure case is a 242dhd look on your tag on the top rear side by the filler plug
