HELP 241 STD CASE VIBES??
T Case pops out of 4 low. Was once not properly engaged, popped out under heavy load. Now must hold in under load.
Changed to 85W140 about 50K miles ago after consulting D/C mechanic. A Vibration is now getting slowly worse during last 30K miles. T Case removed, looks OK, Fork and slip collars look OK, Lube discolored, Oil pick up screen mostly plugged. Never run low on lube. ????? Could the Planetary be causing Vibes???
HELP ANY IDEAS??
241STD
96 2500 EXT LONG AUTO 3. 54 4X4
HELP ANY IDEAS??
241STD
