So like a bonehead I ran my 01 3500 out of fuel the other day, and had a hard time searching for restart procedure, so I thought I would create a thread with all the "correct keywords" in the title so the next guy that does it can find this easily . .
add any other information or corrections, as this is just from my experience.
so with "31 miles to empty" reading on the overhead display, my 01 3500 started making a groaning noise that increases with throttle position
( more throttle more "groan" ) I imagine this was the lift pump sucking air
or maybe the injection pump sucking air. This groaning only lasted about 45 seconds, then I was coastin' and the cummins was unusually quiet.
so my procedure was:
worked for me . .
the very worst part of this was riding back to the house in a FORD tow truck
I had to hang my head in shame
- put at least 5 gal of fuel into the tank
- unscrew the top of the filter housing most of the way to allow air to escape
- turn key on and barely bump starter
- listen for lift pump to operate
- repeat starter bump until fuel just starts to flow out of top of filter housing
- close filter housing
- loosen a few injector lines (at least three)
- repeat bump procedure until fuel starts to flow from around injector seat
- tighten injectors back up
- mop up any spilled fuel
- start er up
- will run rough for about 30 seconds or so
- engine may stall so holding throttle just above idle (1200RPM or so) will help this
- let run for at least 3-5 min to ensure air is bled out
- go fill your tank
- dont do this again
- install fuel pressure gauge (if you dont have one)
worked for me . .
