I have been pondering swapping a 12v engine into my 01 and I need some input on changing things over.
First off, I have always wanted a 12v truck but I prefer the 24v interior. I tried to find a suitable 98 12v truck but in my area they all seem to be either torn up or made of gold. I found an 01 that was setup nicely and was planning on p-pumping it. After much research and thinking I have decided to just pull the whole 24v out and convert the truck over to a 12v. I have searched this subject on TDR, Comp D, Diesel Bombers, etc. and I think I have a pretty good handle on what all needs to be done. I couldnt find any threads specifically dealing with 01 trucks so I just want to make sure I have my info correct before I start sourcing parts and pulling bolts.
With the truck being an 01 I dont think I can just install a 98 12v engine harness and carry on like 98. 5s and 99s can so the sensors need to be delt with. The 24v ECM has to stay for gauges. I know I need to keep the cam sensor for the alternator and such and from my reading, I should be able to use the cam sensor adapter and cam gear for a 24v p-pump swap. Oil pressure and IAT sensors can be adapted to pipe thread fittings and possibly the coolant sensor. I am not sure what needs to be done with crank sensor; can I just install it in the 12v position with the tone ring on the dampner or do I even need to keep it?
Vacuum and PS pumps should just bolt up to the 12v timing case. Hoses with need to be replaced with 12v ones. Throttle cables with need to be converted or adapted.
Am I incorrect on anything or missing something that will need to be delt with?
