Competition 24V Valve Spring Question???
Competition Ever broke the factory 1 3/8 input on 6spd
Competition Best 60' with a stick?
I don't know if this has ever been covered before...
I have twins that make about 60 PSI (with woosy injectors). If the valve spring is able to apply 75 pounds of satic pressure to keep the valve closed, is that enough to keep it closed when there is no cylinder pressure??
I know that on the compression stroke the combustion pressure will be able to hold the valves up, but what about on the exhaust stroke when the 60 psi is pushing againts the intake valves???
If you look at it one way, lets say that the boost does push the valve open, would it assist in evacuating the exhaust gasses???
Just a brain fart... .
And if the above is a problem, where can I purchase heavy rated valve springs?
Justin-
I would at least check yours to test on seat pressure, and shim them . 060" or so if you get serious about boost and RPM. Just be cautious about coil bind.
