Engine/Transmission (1998.5 - 2002) 251 code
Engine/Transmission (1998.5 - 2002) Codes Constant
Engine/Transmission (1998.5 - 2002) Airtex
Today, while trying to get across a busy street I stepped down on the go peddle, the truck stumbled then died. edge comp set on level one. The truck started right up again. the comp shut itself off. Its been running fine so far. Is this maybe just a glitch with the Comp or maybe bigger problems in the future? Code 251 = fuel injection pump mechanical failure fuel valve feed back circuit.
8 codes set
Today I pulled 8 codes, 234, 253, 251, 252, 234, 253, 251, 252. Iam pretty sure it was it the Comp messing up. You know how those things are, don't work when its cold, cycle the key a few times to get in going. I know I did not over boost it, not enough time for turbo to spool before it stumbled and died.
