265x75 Tire Pressure
Where to mount a CB in a 5-spd?
Temp gauges
A question for those of you that have this tire as std equipment, what is the solo tire pressure recommendations for front & rear for extended cab, long bed?
thanks
I try to keep 65 on the steering axle and 60 in the driver's. I tried 60 in the front but looked like it wore the edges a tad too much for me.
I keep mine at 80 PSI and rarely if ever rotate them. My first set ran 65,000 miles with 50% rubber left. Probably if I could stop the truck long enough I would take better care of them... ...
On 4x4 CTD's i like 65 in the fronts,the front of these trucks are heavy,if you run less the tires wear out on the outside edges. I run 45 in the rears,empty,and 65 if im carrying weight.
