275 injectors vs Bully Dog Step 1's
Bright Box - $20.95
Replacing Stock Headlamp Assemblies with Sport Ones
What is benefit of the Bully Dog Step 1's or DD 1's extruded honed injectors, as compared to the stock 275 injectors?
98 24V QC, AT 4wd,4:10 LSD,Driftwood w/leather. Boost, Pyro and Trans temp gauges. X-Line Bed liner. TC lockup switch. BD E-Brake & PressureLoc
Diesel Dynamics has dyno graphs on their site that compares the DD injectors vs. the stock and 275's. I have found their graphs to accurate.
2001. 5 2500 QC 4x4
Cummins ETH 6speed
RAMPAGE!
[This message has been edited by Bill (edited 12-04-2000). ]
Are you sure the Stage I injectors are extrude honed? Did Bully Dog tell you that their step 1 injectors are extrude honed?
Bully dog injectors are extrude honed and individually flow & pressure tested. I know this for sure because I've seen it. I'm not sure that any one else does this or not check it out? I have tried the bully dog and the diesel dynamics and the 275 hp injectors.
The dynamics and bully dog definitely out performed in HP and mileage than the 275 injectors. I felt the bully dog had the edge but they were so close it was scarry.
