OK here's the deal, I have 275 injectors and a comp box with an hx35 and 14cm housing and only getting 24 lbs of boost. I can go under load with my 5er on and on a steep grade and the boost will hit 24psi and stop dead cold, I thought it would be an easy fix by adjusting my wastegate, checked it tonight and it opens at 28psi just like I requested when I ordered my turbo from Piers, my old hx35 with 12 cm housing and wastegate disabled could hit 32 psi... ... ... this is at elevation of 4000 to 5000 ft. OH and it doesnt matter if comp box is on 5x5, 2x2 or off all I can get is 24 psi.
My question is what should I expect to get?
Cheers, Kevin
Cheers, Kevin
