I'm wearing out my front pads 6 to 1 over my rear drum linnings.
Found TSB 05-04-97 that says to replace the rear wheel break cylinders with larger 27mm ones only if you haul continuously at or near 75% of GVW. TSB 05-04-98 discusses removing the rear height sensing unit under similar load circumstances.
I DO NOT haul this heavy continuously, but am wondering what it would hurt if I went ahead and switched to the larger 27mm cylinders anyway OR possibly removed the rear height sensing devise.
Looking for any advise or feedback from someone who's already done this or has experience in this area.
Also, if it's OK to modify the rear break setup, would you recommend removing the height sensing unit before replacing the cylinders?
Thanks
Thanks
