There are none available at the moment. The parts guy at Cummins said he'd have to call and see about availability before he could get a price..... yeah, I know what that means. He said upwards from $2500, so yeah, $3k would be close.
I want to compare the blocks to see just HOW different they are, but I didn't get time today. Daylight is longer, but still not long enough this time of year. My shop is full of '03 and '85 at the moment, so no room there. My block got set up on a bent frame off the hill. I guess that'll go to scrap iron in the next few months.....
The wiring is a pain, I'm sure. I'm fairly certain the heads would fit, looking and measuring the decks, but I'm not sure about the valve clearance, as I don't have a swinging assembly to measure for the '03. As they are very similar cranks, I don't think that'd be an issure. The crank sensor on the '03 is on the dampener, so I don't see a need to change the crank. The pistons are the primary difference that I've seen. I wonder what it would change the compression ratio to if you used the 2nd gen pistons? The housing bolt up is not easily overcome, I don't think. The whole shebang still needs another look, maybe. I'm curious, too, as to just what the main differences are. I'm pretty sure the '03 block has a heck of a lot more freeze plugs than the 2nd gen. for both water and oil.....
And at the moment, these are obstacles, as I need the truck up and running by the end of the month, before we start working cattle again. I'm blessed to have another one to drive, a '97 3500 4x4, but the fuel mileage sucks on it. The cam is seriously retarded, as the engine came out of an F-650 with an Allison behind it. But I'm not touching it until I have this one fixed!! Or else I'll be driving my '01 gasser to beat on!!
God bless,
Casey
