2nd Gen DRW to SRW Conversion
4bt and 6bt flywheel housings
transmission Q's for 4bt to 74 power wagon
I know it's been done on the 3rd gen. vehicles but what is involved with converting a DRW 2nd gen. to a SRW? Is the axle a different width or something?
Thanks.
If I am not mistaken there is a difference in wheel adapter out on the end of the axle. I know that have been people that have switched to duals using a singel with the requirement that they had to just get the right adapter/parts. It is on the forum in the older threads, just cant remember what it was under or called. :confused: If you can find that thread, that might give you the info you need to figure out what you would need to do.
