I have to apologize if some of this is common 1st gen knowledge. I am a 2nd gen'er. A good friend of mine has a 91. 5 though and I'm wondering if some of my parts would be beneficial to him or not.
My truck is a 98 12-valve. I am about to put a PDR cam in my truck and am tempted to pull the head and stud it while I have everything else apart. With the deal that PDR is having on new heads, I'm very tempted to get one of those and have it ported and 60# springs. Are there any differences between the heads on 1st gens and 2nd gens? I'm wondering if the 2nd gen heads flow any better than the 1st gens and will mine bolt right onto his engine. If so, then I'd sell my old head to him and get a brand new head. If there aren't any advantages for him though, I won't bother with it. I'd only sell it to him if it'll help him out and I could get enough money out of it to make it worth buying a new head. I'd like to be able to get at least enough money out of my current head to cover shipping cost of the new head and a new marine head gasket. Injectors are different, right? Would he need 2nd gen injectors to run this head? If so, will the connectors on the fuel lines fit 2nd gen injectors or would he need to change out fuel lines too? What about intake parts and exhaust manifold? Does all that match up?
Also, how beneficial would my hx-35 be to him? I have heard of 1st geners putting 35s on their trucks but I'm not sure if that is on pumped up engines or stock. His truck is bone stock. Without mods, would a 35 help him or not? I have a non-wg 16cm^2 housing on it now but also have my stock wg 12cm^2 still too. Which would be better for him? I am looking at getting an S-3 but only if I can unload my 35.
Since I'm on all this too... I recently upgraded from my old nv4500 and SB Con O clutch to an NV5600 and Con FE clutch. The 4500 has a full-splined main shaft and new input shaft but I broke 3rd gear that still needs replacing. He is interested in this too to get rid of his auto. I've heard he would need a special bellhousing to run a 4500 behind his 1st gen 12-valve. Is this because of the flywheel or is there something different between the cranks of the two engines? Because I pulled everything from the flywheel back from my stock setup.
He is a very good friend of mine so I'm only going to do any of this if it is a win-win situation.
Thanks in advance and again - sorry for my ignorance.
