2nd Gen Non-Engine/Transmission 2nd gen steering problems
  • a. tires
    Votes: 2 5.4%
  • b. steering gear box
    Votes: 4 10.8%
  • c. steering shaft
    Votes: 3 8.1%
  • d. your mother-in-law
    Votes: 2 5.4%
  • e. steering linkage arrangement/engineering
    Votes: 9 24.3%
  • f. poor linkage components
    Votes: 5 13.5%
  • g. liberals
    Votes: 3 8.1%
  • h. all of the above
    Votes: 9 24.3%
  • Total voters
    37
  • Poll closed .
In your opinion what is the source of 2nd gen steering problems?
a. tires
c. steering shaft
g. liberals
h. all of the above
My vote would be the coil springs and a track bar system. These trucks should have leaf springs to take the load better up front.
Bad shocks would have an effect on the steering/suspension/handling. I've ben able to adjust out most of the slop in my box.
I love my coil springs and have no desire to go backwards to leafs :) . When everything is right on these front ends(not worn or damaged) they work great.
Bob
I voted all of the above. Been chasing steering/handling problems for close to a year. I am getting ready to swap over from the inverted Y to the inverted T tie rod setup and swap in the 4th steering gearbox. Trying a PSC gearbox this time. No luck with a rebuilt GB and two new GBs(too much slop which can't be adjusted any tighter). Everything(and I mean everything) on the steering and front suspension has been replaced from the firewall forward except the front axle, still drives horrible.
Steering problems?
WHAT "steering problems"?
Mine steers perfectly - and has from day one - 32,000 miles on the truck, and tires still have about half their tread left. 4x4's might have more problems (which is why I avoided them like the plague!), but my 2x is flawless...
How about a selection for "NO problems at all"? ;)
What problems are you having? I changed out a set of shocks and a stering stabilizer and it drove like new. And after 130,000 of loaded to the hilt driving thats not to bad.
I did have a problem with the type of tire I was running. I had BFGs on it when I first got it, and then swithced to a Cooper M/S then a set of Revos. The BFG's are a little to square on the edge and seamed to wonder a lot more than the other two brands.
IMO I would check to make shure your shocks are in good shape and put in a luks link kit and then work from there.
Action ------------------------ Effect
accomplished TSB --- still dls
installed DSS --- better/still dls
heavier front springs --- still dls
new KYB shocks --- still dls
installed luke's link on track-bar ---still dls
re-accomplished tsb --- still dls
instal HD steering box --- stand-by
JJ
Steering Wonder
I would have to say my biggest improvment was the steering stabilizer the attaches to the frame and your steering box made my steering tight as a new truck. Oo.
