2WD-Lo Switch?
McLeod is in, I like it!
Prime-Loc?
Fellow Rammers:
In issue 29, on page 10, there is a picture of a vacuum switch (I think) that you can install to disable front axle when transfer case is shifted in 4WD lo. Does anyone have a manufacturer/part number?
This would really be cool for manuvering real heavy trailers up tall grade w/ out smoke'n clutch (2Hi) or binding the driveline (4-lo).
Appreciate any help,
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch.
Wiredawg,I bought mine from BD,It came in kit with good directions,nice lighted switch,and wire. I have 6speed and mounted the switch on shift pedestal between the 4 whl drv lever and main gearshift. As I recall it was around $90 for kit with shipping.
I like it. Works just like you are intending
I bought mine from BD as well. It uses the same solenoid they use for their exhaust brakes. It also has a good bracket and switch with a nice looking legend plate. Sure you could make your own for about 1/2 but that would take a lot of time that I don't have.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
78,000 miles (11/17/00)
