Hey all,
For those of you that have ever had or have a 2wd ram truck. Did you ever replace the lower control arm bolts when you replaced the lower control arms or did you just reuse the factory ones?
I keep getting a clicking/ popping from my driver side at the lower control arm where it bolts to the frame. I have made sure its at the 190ftlbs torque that is recommended and I have even gone over that as well.
Could it just be the 1a-auto control arms that I am using that is causing the problem or should i just get under there and torque them higher? Or replace them? I imagine that I can replace them 1 at a time without having to tear the front end apart again?
