I'm sure this has been discussed before but I am having no luck finding it anywhere.
Does the TPS determine when the shift from 3rd to 4th (OD) occurs at WOT? I took the slack out of my throttle cable and adjusted my low idle the other day and consequently needed to adjust the K-D cable. Easy enough. With these adjustments made, I could not get the transmission to stay in OD at WOT. I flipped my TPS and used a cotter pin to keep it turned. Now the transmission goes in OD too quickly after the 2-3 shift. I've made several adjustments on how much it is turned but so far, I have not found a setting that changes the shift point. It pulls hard once in OD but I know it has to be hard on the OD so I want to get it shiftin at the right time.
TIA,
Carl
TIA,
Carl
