2nd Gen Non-Engine/Transmission 3/4 ton to 1 ton brake cylinders.. how hard?
Engine/Transmission (1998.5 - 2002) Off-idle engine sound w/ DD2s
Engine/Transmission (1998.5 - 2002) Oil Pressure Gauge Malfunction?
Changing rear cylinders
If you have ever done any drum brake work, you should have no trouble. The most difficult part is bleeding the brakes. I use a bleeder made for a 1940 LaSalle.
Before you buy new cylinders, though, make sure that yours doesn't already have them. In the late 1990s, D-C changed the setup so that the 3/4 ton got 1 ton rear cylinders. I cannot remember which year was the change, since (1) it didn't affect my 1996, and (2) my memory is awful.
One way to check this is to go to a decent parts store. If the 3/4 ton and 1 ton use different part numbers for your year, buy a set of the cylinders for a 1 ton. If they use the same number, don't bother.
I think 1998 was the year of the changeover to the larger cylinder from the factory, but not all 98's had the larger cylinders.
I thought it was about then, and maybe a midyear change. When I swapped mine out, the difference was astounding. It stopped better, and quit pulling to one side or the other. I wish I had done it the day I drove it off the dealer's lot, except it was dark when I signed the last paper. ;)
Mine was is a 98 12V and it already had the 1 ton brake cylinders on it already. You might want to check that before you go by some new ones. Run the part #.
Originally posted by charlan
is it a PITA to bleed these out???? I got short on time, and have to do it tomorrow.
-Chris-
Do yourself a favor and go buy yourself a Mityvac.
Note that the Harbor Freight Tools has it MIS-spelled as Mightyvac!
