If you both have same rearend and it is not a 4x4.
I wonder if 3. 42's are available in 4wd?
It would be so sweet to have a 68RFE and 3. 42's. Talk about a highway cruiser!
Merrick
essentially a 4speed w/2 ODs.
The 68rfe is a long ways from a 4 speed with 2 ODs. The 1st & 2nd. are lower that a 48re's 1st & 2nd. Makes for much better launches.
CUMMINZ
CUMMINZ
I get what you're saying, but 5th and 6th are OD gears. By definition, an OD gear is any gear that causes the output shaft to turn faster than the input shaft. The old 47/48REs were 3 speeds with an OD. The 68RFE is a true 4 speed with a double OD, which is why it has a lower first gear, and closer gear spacing. No, it's not the 48RE with two addl gears added. If that's what you meant, you'd be correct.
You mentioned in your first post "3. 42 rear end". I took for granted you were wanting to just change out the "rear". Yes you can change out both.
Thanks. So, if I changed the ring and pinion to 3. 42 in both front and rear differentials, what would I need to do to ensure the speedometer and the electronics on the 6. 7 aren't screwed up?
Reason I'm asking is I'm in the process of buying a 2007 QC 3500 6. 7L 4 X 4 SLT with the G56 6-speed. The 68RFE sounds good but this is too good of a deal to pass up--I'm getting this thing for $31K!
Any idea what the costs involved would be switching to a 3. 42?
As for swapping, check on your RPMs. You may have the "AE" model G56 with a . 74 top gear instead of the . 79s found in the original "AD" model (05. 5-06) that are the complaint. Does your truck hit 64 MPH or 68 MPH at 2000 RPM in 6th? If I had that model G56, which they started putting in the trucks in 2007, I wouldn't worry about the 3. 42s, but that's just me and "one man's opinion. " You can look at the klenger.net pdf that I linked earlier in this thread. Go to page 2 and compare the two trannies and you'll see what I'm talking about.
