I have a 99 w/3. 55 and 285/75/16 and like the way it runs. The only thing with that combo is that I shy away from pulling anything over 10000, and, keep it out of overdrive with anything over 5k (mainly due to having a manual w/the infamous 5th gear nut problem). When I ran stock tires I ran 2500 rpm at 80. With the taller rubber, I run 10% lower (2200 at 80). If you hit dirt, I would say hit a 285/70/17, but if you run mainly road, I would try to find a 255/80/17. The 255/80 and 285/70 are just as tall, but, the 255 is about 1. 25 inches thinner.
