Total hours... how do u find driving hours?Total hours or driving hours?
Mine is 63.5 MPH average for driving hours.
On my EVIC screen it shows driving hours, idle hours and total hours.Total hours... how do u find driving hours?
Another metric to over analyze!
Well... I don’t have that level of detail on my 2012... only engine hours... just divided my total mileage by the engine hours as I was curious as to the mileage per engine hour... your % of idle time was interesting Wiredawg... I think I am in the single digits but have no way to know accurately...
Ahhhh ... didn’t think of it that way...u r right... never factored that inIt is doubtful your idle hours are single digits as anything with the rig stopped, in gear or not, is idle time. Every 2 seconds at a stop sign, 30 seconds at a red light, 2 minute cool-down, stop and go traffic, etc adds up.
8% idle time is considered very low.
Cummins considers anything over 16.6% excessive.
Well, I have almost 4 times as many driving hours, but only twice as many idle hours.Here is my latest. I don't feel like I idle much but by the numbers it says I do???
View attachment 126476 it says I do.
That's quite a bit of idle time.Well I just thought of something I do. When towing our 5er I never shut the truck down until I get to my destination. Fill ups and rest stops it's left running.
Excessive idling will load up the dpf, cause the ecm to command more frequent and longer regens.Interesting... thank you everyone for their comments so far... when I posted this I was curious as to idle time as other threads on this forum viewed idling ina negative fashion... I warm my truck up ALOT... plug it in every night below freezing... remote start and idle for 10 minutes or so... it gets cold up here, but even on “moderate temps”... I idle up... even use the idle up feature..granted only 104k miles but the process has not been negative...as an example... I normally wait for the trans temp to get to 90 degrees before moving out of park
Soooo now u have me thinking,,, idling to warm up the fluids detrimental ?
This forum is great! Thanks for your thoughts in advance
Thank you very much... DPF? What is that?Excessive idling will load up the dpf, cause the ecm to command more frequent and longer regens.
Do whatever you can to keep the idle time to a minimum, and when you do idle for longer periods, always set the high idle, that will help reduce the extra load on the dpf.
Really?Thank you very much... DPF? What is that?
