315/70R17 on a Dually ?? Please respond
Ball joint re-use?
35 x 12.50 ??
I'm not familiar with that tire... but I'd find a tire guide and look at the specifications for that tire. . I'm guessing that you don't have the correct wheel width for the tire to fit correctly and give you proper wear. .
But looking at the tire guide will give all you need to know to understand wheel spacing, tire bulge, and rim width. .
BTW the tire guide I'm speaking of is usually on the web sight of the tire manufacturer that your thinking of buying...
I put some 315/70R17 Mastercraft Courser ATs on my '03. I had to use a 2. 5 in spacer to get it to where I wanted it. I've got some Bushwacker fender flares to put on it, that will cover them up for the most part. They can get your mirrors with rocks and such. I've been lucky and they've missed but I see them pretty regular coming by the driver window, just above and below the mirror... ... And in the mud, you can gaurantee it to COVER the side of your truck with mud and grass. I've got some custom fabbed steps and mud flaps behind the front tires as well.
