319 HP on G-TECH
3 guage pod search
Couple of new Product Reviews on the site
Just ran a couple of tests on HP on the GTECH and my peak was 319. Measurement was from a dead stop up to 90mph. How accurate is the GTECH I entered my weight as 7500? Is there a hp to lb chart or scale?
Jim
Patriot blue Y2k 5sp Stealth 2500 (markings removed)QC,SLT+,leather, camper,TT,lsd,3. 54,4x4,hd xfer case,Geno's dual gauge,DD IIM's and boost module,K&N stock filter, Tekonsha Sentinal,Reese 12 hole wd hitch, ARE lid & bedrug liner, Sony 10 disk cd changer.
To be accurate you should have your truck weighed on a scale. The proper vehicle weight is important in the calculations inside the G-Tech. To high of a weight entered will give you a higher than true hp. reading. My truck is 6600 lbs. with a full tank of fuel and my son and I in it.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
[This message has been edited by Paul (edited 08-12-2000). ]
My experience it you need to throw out the peak reading. My peak was 750, a bit high #ad
The other readings were very similiar and matched the dynojet readout. Do 4 runs and throw out the high and low then average the two middle readings and I bet you will have a good number.
Well, I didn't get my ram weighed but after reading the thread of "how much does your truck weigh" I decided on 6700lbs. I have a quad cab 4x4 with hd everything. Fiberglass ARE lid and I'm 250lbs, full tank. So I feel this is conservative.
I made 4 new runs like HVAC suggested.
1st run 345
2nd run 285 forgot and left air on.
3rd run 300 even
4th run 305
I do also hit 31 lbs + of boost on my guage
so the 10hp per lb of boost is close to the G-tech. Not knowing how much power is leached I'm still guessing. All in all I'm happy with my IIm's and boost module.
Next step maybe for Christmas PE hot #3 #ad
Jim
jims,
I have an identical truck to ours,with the only exception being the 6spd. My truck weight is 7300lb(my 99 5spd was 7200lb) and I also have the DD stage IIm's,eblow,module and K&N. I dynoed it on BD's dyno in April and it showed 295hp.
-Mike
'00 QC 2500 4x4, 6spd, LB, LSD, 3. 54, SLT, Dark Garnet, Agate, Camper, Trailer, Fogs, Clarion 6-disc, Smittybilt nerfs, Midland CB, Isspro pyro & boost, K&N Scotty Air, 3" pipe bomb, 2wd low, OEM tailgate lites, Tow hooks, DD stage II, BFG 285/75, 5. 9L R/T
A vulgar display of power!
Mike,
So if my weight is close to yours I should get a higher hp reading if I up the weight. If the G_Tech I have is accurate my injectors are exceeding expectations.
Jim
For you DRW/4x4 owners:
I weighed my '01 3500 4x4 at a truckstop CAT
Certified scale last week. Full of fuel, me
and the wife, the scales totalled 7,740 lbs. Remember, this is a duallie 4x4 (6x6!).
Only thing in the bed is Line-X sprayed in
bed liner. Wife and I together weigh about
310lbs; a full tank of fuel is about 210lbs;
so a basic empty weight of 7,200 lbs for a
DRW 4x4 5spd ram is pretty close.
Chris
'01 3500 QC 4x4 SLT, Dk. Garnet Red, tan interior.
Cummins ETC, 5-speed, 3. 54 anti-spin; Line-X
BOMBed! Power Edge module, Auto Meter boost and pyro
gauges on A-pillar; Valentine One
Kenwood TM742 tri-band Ham Radio VHF/UHF/6M & GPS
APRS Tracker N5CWM-14
My 2001 Cummins Ram modifications website
May the Boost be With You!
jims,
Unless DD slipped a set of stage III's in your stage II box,the G-tech seems to estimate a little on the high side. Guys with stage III's are cranking 315-320hp on the dynos. Seems like a pretty good unit though... I'd like to try one. Does the G-tech estimate rear-wheel hp or flywheel hp?
-Mike
The G-Tech measures(as I understand it) to the ground HP. It works off of G forces acceleration time and weight. So everything affects it (wind resistance, up-hill, down-hill, etc. I was told it should read less than a dyno because of these factors. Of course if you put in way to much weight and run down a 6%grade your going to have monster HP numbers.
Jim
