First Tow with the HO 6 Spd. Started with only 685 miles on OD.
Weights = Truck Empty Front Axle= 4370
Rear Axle = 2890
Total = 7260
With 5th Wheel Front Axle= 4470
Rear Axle = 4990
5th Whl = 7550
Total GWT = 17,010
Went to Raton, NM for the NRA Nat'l Shoot and then up thru CO and Wyoming and back to CA. Lot's of hills. Had to drop into 4th for a few of them. Was pleased with the power and have an EZ to install after a few more break in miles. I averaged only 10. 7 mpg for the 3281 miles (actual, not Computer generated) I am happy with the mileage as it seems better with more miles on the truck. It pulled better and got better mileage the last 1/2 of the trip. I was towing at a steady 70 most of the time after leaving CA. I see what you guy's mean about backing up and the clutch wanting to chatter. ! I know, I was 660 lbs O/Wt on the truck. I will run without the fresh water tank full in the future. The Pac Brake is a Winner. ! Good Rig, Good Trip.
Rear Axle = 2890
Total = 7260
Rear Axle = 4990
5th Whl = 7550
Total GWT = 17,010
