3400# 16x8 wheel recommendations?
Getting ready to by the Rancho 9000's.
Mexican Bardahl mudflaps??
Anyone know of a 16x8 wheel that is rated at 3400lbs?
Have a 99 2500 SLT/Quad Cab, 4x4, Camper group.
Carry a truck camper. Would like to go with 3400# rated tires with equivalent rating on the wheels.
Thanks,
JP
jpzeroday@hotmail.com
The only ones I know of are from Weld Racing, the F-1 one piece wheels. They have 3 different styles and are rated at 3500#.
"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's LSD, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), 285/75R16 Cooper A/T's.
Things to come;
Pyro, Boost and Fuel Pressure gauges and injectors.
NRA Life Member! (Need to protect our rights and FREEDOM!!)
The forged aluminum Weld Racing wheels are rated at 3400 lbs. each however, the forged aluminum M/T Alcoa wheels are actually stronger. Both are the best of the best as far as wheels are concerned. #ad
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Bypass, Optima yellow tops, Bosch 275s, VA CPC, (censored), Aeroquip braided s/s fuel lines, Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
Thanks for the information.
I am looking for a tire/wheel combination that can handle a truck camper.
I have seen posts on the BF T/A rated at 3405# (I believe), but this tire is a "D". Are there any all terrain tires rated at 3400#+ and "E"?
Thanks,
JP
'99 2500, 4x4, Quad Cab, SLT, Camper Group
'00 Lance 815
