35.6 gal into 34 gal tank?
Have you gone DRW to SRW? Do you still have your dually lugnuts?
4WD Alignment
Can anyone tell me how I put 35. 6 gallons of fuel into my 34 gallon tank? I was pretty low, but I know I wasn't running on NEGATIVE! #@$%!
No vent mod, and I put in about 2 gallons after the initial click off. It did not come up the filler neck.
I frequent this station and my suspicions have been aroused before so I wanted to see how much I could fit.
Heck, I want to know how you could afford it, Take out a bank loan??
Anyway My "03" Shop manual shows the short bed holding 98L or 26 gallons. The long bed holds 132L or 35 gallons. The note: Nominal refill capacities are shown, A variation may be observed due to blaw blaw blaww, you get the point.
The most I've ever put in mine is 34 gallons, the trip meter DTE was on 0 and the chime was on constant. :D
Maybe they are scamming you.
If the high prices aren't enough.
If you're suspecting fraud from the station, I saw something about that on TV a few years ago. There was a place out in CA (if memory serves) that had some complaints against it, but every time the Dept of Consumer Protection went out to check by filling their 5 and 10 gallon official tanks, they couldn't find anything. In the end someone found a computer chip on the inside of the pump that was programmed to make the 5 and 10 gallon amounts accurate to fool the inspectors, but fraudulantly bumped up the gallon count at other quantities. They said it took a computer scientist to figure out what the thing did once they found it. They station owners were charged for this.
I can't imagine there are too many guys out there pulling this stunt, though. I may be naive, but I'd have to guess that the majority of stations are on the up and up.
What about the reserve? The owners manual says that there is something like a 10% reserve from when the overhead computer starts to read zero.
You can put 38-39 gallons in a short bed truck's 34 gallon fuel tank.
You can put 39-40 gallons in a long bed truck's 35 gallon fuel tank.
How much you get in depends on how much you want to nurse the fuel going into the tank. Putting 35. 6 gallons in is not unusual if conditions are right.
My tank is vented and I have put in 36-37 gals in it without having a fuel light come on, the gauge registered just below an 1/8th of a tank.
42 gallons
I installed a vent kit, and before reinstalling the fuel tank I had wiped it down and so it was dry and clean.
My first fill up was almost 42 gallons
I like the vent kit, the bigger tank help a ton on longer trip, but it hurts filling it up now. 4. 89 a gallon here in pittsburg
Joe
