35 inch tires
10" wheels
limiting straps
anyone running 35x12. 50x17 on 17x8 aftermarket wheels with only leveling kit just purchased 35 in procomp x terrains and compared to my 33 inch tires look very big thanks
I have a 2-3/8 lift that I made myself for the front, running 35, they are close but they work, it really depends on what offset the rims have.
I ran them for a short while on stock wheels and stock suspension before putting on the KORE. Just a little rub on the control arms. No fender contact.
Gary
I have 35x12. 5's on mine with stock rims and stock suspension. I didn't rub at all even with a few runs at Glamis.
I don't get it? When I got my truck, the dealer had put 315 BFG Allterrain k/o's around the stock wheels, and they rubbed the lower control arms on full lock. I told them to swap the 315 for the 265' after I could not take the rubbing pulling into my driveway. Matt i'm curious? what did you do to keep your tires from rubbing the inner control arms? Everyone I know has had the problem with this size tire on stock wheels?
-Ryan
The 315's just kiss the arm,not enough to cause any concern. If you are worried about it Run KOREs billet arms they will clear 37's :D
Bob
so are you saying i can run 35's on my 05 4x4 SB QC with stock rims and only have a little bit of rub on the control arms. If so that is great cause i hate my 265's. The damn truck looks all unpraportional. Anywho is running a 34 maybe a better idea to be safe and is there that much of a difference between 34's and 35's when on the truck, looks wise anyway.
It might be because my tires are H2 take-offs with around 5k on them. They aren't brand new. I dont' hear or see any place that it is rubbing. They are BFG AT's.
Bob
Are there other brands of adjustable control arms out there besides Kore?
LR
any reccomendation on which set of tires to go with? I don't do much off roading but i do like the look of those mud tires. I will be saving up for them in the next 4-5 months or so nothing fansy like the big dogs use. I do like the bfg's and i think there is another called like nitto or something that look pretty good so cheap but not the cheapest.
I'm running the 325 70 17 on hallo wheels with a 2 inch BDS, which I like how it's made, and I have a little rub on my fender flares.
