35" pro comps will they fit?
Is the overhead mpg reading really less accurate than a hand calc??
Sirius Plug-n-Play Install?
I have some pro comp 35 for my 05 6sp CTD 2500 4x4 quad cab Think they are going to fit?
I don't mind trimming some just want to know if they will fit enough to get home from the shop and trim at home.
Thanks,
Mike
If you stay with the OEM wheels, they'll rub only slightly during lock-to-lock turns... . no leveling kit needed. Throw in aftermarket wheels and it all goes out the door; most likely it will rub some. I have a friend with an '05 RAM 2500 4 door 4x4 and he runs LT35x12. 50R17 Mastercraft Courser C/T's..... his truck has the Off Road pkg (4. 10 axle) so the 35's work great for him... . pic attached.
Greg
yes they will fit. I've had mine on for two days now, the only rubbing I have is where the mudflaps overlap the inner fenders on the front. They ride good, but after I get skyjacker d25s I will be aligning it. Speedo with 3. 73 is off by 5 at 55, checked today with gps.
They fit no problem.
If I turn all they way and really pull on the wheel they hit my control arms but I really need to pull.
thanks to all for your help.
now just waiting to get my edge juice back (updating software) and put it and my EZ in and see if I am going to like it.
Also thinking about kore control arms that are cut out just so I don't need to worry about it and then maybe even go up to 37's.
