35 x 16 Tires
New guy an the block
New rules
I understand BF Goodwrench makes a 35" radial that fits our rims. Anyone have a set or any other brand in the 35" size?
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
Hi Chad,
Yep, 315's and I'm runnin' them on the stock rims. Follow the link to my pics OR
I can send you some others.
Mick
<font color=blue>
2001. 5 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Totally STOCK!!
On Order 4/28/00
Arrived 9/14/00 !!
My Truck
[This message has been edited by Mick2500 (edited 03-01-2001). ]
Chad
I have a set of BFG A/Ts. They are 295/75r16 equal to 35 x 11. 50. (actual measurement: 34. 4" H) THEY ARE GREAT!! Load range D. I researched 15 different sizes and brands and came back to these every time.
Jeff
I'm with Jeff, Love the 295's. They don't spray outside the fenders to bad, and no risk of rubbing.
I wanted the 315's too, but was worried they would ballon out from the stock 8" rims to much and have a detrimental affect on tire wear.
Plus if you run 3. 54 gears you'll be a little happier with the acceleration.
If I ever run 315's I would get 10" wide rims to minimize center tire wear, Then definetely get fender flares, Then BOMB the S%*# out of it #ad
Kevin MacGranor
2001. 5 D2500 QC SLT 4X4,Auto 295/75r16 BFG AT's, Century Cap, Bedrug. , Alpine Head & Amps w/ Boston Acoustic speakers & JL Audio Stealthbox center cushion Sub.
I run 315/75R16 Pathfinder ATRs (Americas Tire) on my '00 - factory alum wheels. They calculate out at 34. 6in OD x 12. 4in wide. The look fine on the 8inch wheel - don't balloon out or stick out beyond the fender. I've got ~23k miles on them and they don't show any abnormal wear - I set tire pressure to achieve full contact across the width of the tire. The only problem is that the tires do rub the lower control arm before full steering lock.
FYI - 295/75R16s calculate out to 33. 4in OD x 11. 6in wide.
Brian
[This message has been edited by Brian Meadows (edited 03-01-2001). ]
I still can't believe all the great info on this site. Please let me know if i'm getting this right, 295's don't rub at all on stock suspension and 315's rub a little? I run 285's now and was wandering whether I could run either of the others without mods to the suspension on my new one. If I'm not pressing my luck, was wondering if any of you had run the 255-85 BFG mud's. Worse tire noise than BFG AT,s? Worse tire wear? Worse highway all season traction? Thanks alot ,
Doug
red 96 x-cab 2500 lbox v-10 5-speed w/4. 10s soon will be red 01 q-cab 2500 lbox HO 6-speed w/3. 55s
I'm runnin' 315 X 70's on 16 X 7 Alcoa's, no rubbing, But the 315 will bubble out on 7" wide wheels, I wouldn't go any bigger... .
1999 Quad CAb, Short Bed,4X4, Sport Package, 6 speed, 4. 10 rear, Camper Package, MIA Silencer Ring, Amsoil Air Filter, VA CPC, Bosch 275's, Practical Solutions Boost Module, Custom Dual 3" Exhaust with dual 5" Tips, BD Exhaust Brake, Alcoa Classics.
How do y'all recalibrate the speedo/odo/abs/transmission or whatever else is affected by changing final gear ratio i. e. tire size?
Mick
Still haven't decided what truck to buy. DC VS F*** VS Ch*** !
Mike2500,
Are you running the 315's without any lift whatsoever. If so, do you have any problems as far as rubbing when you turn sharp or anything along those lines. Just curious.
Chris
2001. 5 2500,QC,4x4,ETH/DEE,Dk. Garnet Red,Agate,E-Brake w/shifter switch,silencer ring AWOL,every option but leather. 1100 miles as of 2/18/00
I ran 305's on my 96 gasser. It had 6" rims. Ballooned a little. Still carried the camper fine. They were Goodyear ATS if I recall. Nice and quiet.
Traded a fully loaded 96 V10 for a 01. 5 4X,QC,LB,auto,3. 54,everything but leather,Patriot Blue
2000 Alpenlite Rainer DX slide in
1998 Neptune 230 walkaround sport fisher
Clarification on previous post:
I run the 315s on the stock alum (16x8) wheels w/o ANY lift and have rubbing on the lower control arms before full steering lock. I do not off road my truck so I do not know if the tires would hit the fenders on full suspension compression.
Brian
