Watch the eyelets on the Ranchos
If you go with the Ranchos on the front, make sure the lower bolt correctly fits the hole in the lower shock. If the bolt is a little bit too small ... you will have a rattle in the front end that will drive you INSANE!!! You will need a spacer if this is the case.
I can not use Ranchos on the front of my truck because of this issue and the inability of finding a spacer for the bolt and eyelet hole on the shock.
