35's with just a levelin kit?
06 Computer Codes List?
Which Injectors, Mach 1 Or Flux 1
who out theres runnin 35s on just a leveling kit? i have been doin some measuring and it seems like theyd fit... . anyone have and pix of theirs or someone elses trucks on 33s or 35s? im thinkin of runnin parnelli jones dirt grips in the 35/12. 50/R17 shoe size.
drasko
I have 2 friend's with 3rd gen truck's, 2" leveling kit's and 35's. They both look good and fit fine. I think the wheel offset is where some people have rubbing issue's, but I don't know what that offset is. My '01 has 0 offset and I'm planning on moving from 33's to 35's with my 2" leveling. Not sure if that is the same for newer truck's. Good luck.
i have stock wheels with 35 toyo m/t and they only rub the control arms very little. only notice it when parking in small spots... ... .
I have Moto Metal 950's in 20x10 on my truck with 35" Nittos. -12mm offset and 5. 0" backspace but they still rub the inner fenders at the rear of the wheel well with the Kore leveling kit.
Just ordered longer front control arms to move the front axle forward, which should help it. Plenty you can cut up front, but not at the back of the wheel well.
I have the KORE leveling kit, H2 wheels and 315-70-17 BFG KO's. There is plenty of room, only get a slight rub on my mud flaps at full lock. Many guys are running the same tires as I am without leveling on stock rims. You might have a little more rub with 35x12. 5" wide tires, my BFG's are 10. 5" wide. In that case you will need to lengthen the front control arms as was said ^ by Keith.
CD
I have ProComp 35x12. 5x17's on the stock aluminum wheels on my 2WD with no leveling kit. They fit fine even on the 2WD. I have a little rub on full lock, and occasionally, the top of the tire hits the fender inserts. Normally while crossing the ruts in the traffic lanes or taking speed bumps faster than I should. Without any lift/leveling, the front wheel wells are filled more than I'd really like. I am thinking of moving back down to 33 inch tires when these wear out. Attached is a crappy dark picture from my cell phone. I'll look for a better picture when I get home today.
Carli suspension level kit/starter system
I was running 315/70/17 BF Goodrich all terrains on hummer h2 rims without any leveling kit. With that setup I had no rubbing at all.
I recently installed the Carli suspension starter system and my summer rims and new tires. I have Weld Velociti 8's 17x8. 5 with 5. 14 inches of back spacing with Toyo Open Country Mud Terrain tires 35x12. 5x17 and the only time they rub is turning into a raised driveway/street.
Hope this helps.
