HEMI®Dart
We took off my Denman Coyote LT305/85R16. About 36" tall & 10. 5" wide and bolted them on a '99. We drove for 15 miles. The front tires only rubbed the plastic inner fender liner once hitting a small bump pulling into the driveway with the wheel at 3/4 turn. Had to remove the OE moulded Dodge mud flaps on the front fenders. The tires would contact in a turn. Note how the tire sits inside the wheelwell. Maybe 1/4"stuck out. Plenty of room on the lower fender sheetmetal. Jeff didn't get the vague steering I did with these tall sidewall tires. He loved them
Truck takes on a whole new appearence with the large wheel openings filled up. We really needed to take before & after pictures. The 36" tire compared to the 30" OE tire is incredible. It looks way too tall to ever fit.
Jeff (a TDR member) is thinking about a 2" leveling kit to be able to run them without problems.
This is what I did. They haven't rubbed me the wrong way in 3 years.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 03-11-2001). ]
