Just took my 370's out for the winter. Why? So I don't kill myself or someone else. . The power right off idle is Fricking Fantastic when it's on dry roads, but deadly if the pavement is wet, or heaven forbid, icy!
Now that I've got everyones attention, here
are my questions:
1. How can I get the power curve up a little higher (rpm wise)? Off idle it's a freight train, then about 2100 there's a slight power loss then about 3000, the horses get kicked in the rear again, and away we go. (then I chicken out due to the high EGT)
2. How do get my EGT DOWN?? I can hit 1500 deg. in less than a 1/4 mile. I've only done this twice and the first time it scared the **** out of me. My boost gage only goes to 30
and the needle goes WAY past 30 when this happens. Stock turbo and 4" exhaust all the way back. Plate has been moved from full forward to just back of stock position, with very little difference in EGT.
3. Is it my plate? I'm running a JRE stage 3.
I put the gov. spring kit in and was very dissapointed with the results using the 230 injectors. Had great power off idle but lost power and S-l-o-w EGT build up at around 2100
rpm. (EGT would only go to 900) When I installed the 370's, wow. Had plenty of power, but too much EGT.
I'd love to keep the 370's in, but I've got to figure a way to control the power and EGT first. Piers? KoaMan? John? Thanks guys.
NOTE TO SELF: This trying to run with the big boys is going to kill me... ... .
97 2500, extcab, 4x4. BFG 285/85/16 AT, JRE Stage III plate, BD gov. spring kit, AFC spring kit, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil& transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
are my questions:
