370's are back in and YEEEEE HAAAAAA!!!!
Exploded view of pump
BD Gov Spring Kit and other mods
My truck now has the best of both worlds, smooth controlable power from off idle, to near mid throttle. From mid throttle to WOT it's just awsome!!! I am one happy camper!!!
I went to Dave's Diesel in Angola, IN.
Rick removed the pump from my truck and handed it over to JP, his master pump tech. and after grilling me for about an hour on what I wanted the truck to do (they kept laughing at me as I only ask them to make it do everything, i. e. drag racing, good street manners, good milage, mega power with no smoke. . ) I felt like a kid in a toy store knowing that I could only have a few of the numerous options before me. BUT I WANTED THEM ALL!!!
I'm here to tell you, they came close to giving me everything I ask for.
Rick and the guys there allowed me to observe EVERY aspect of the process including
being in the pump room while they were setting the pump up. It appeared that my pump was retarded quite a bit and it was off on rack travel and the BD Gov. Spring Kit was causing a lot of it!! Yes, we removed the BD spring kit. It was one of my biggest problems. We tried to get it to work but it wouldn't meet the mid range parameters we wanted. So we removed all the BD stuff but the bottom spacer and put the stock springs back in. Wow!!! The pump really came alive then. Rack travel did what it was suppose to do when it was suppose to do it, and full load rpm was set where I wanted it. They explained everything they were doing every step of the way.
I has a very enjoyable and educational day with Rick and JP and am extremly pleased with how my truck runs now. I would highly recommend them to anyone thinking about pump work. Dave's Diesel is truly a professional shop that listens to the truck owner, and their prices are very good too!!!
97 2500, extcab, 4x4. BFG 285/85/16 AT, "warmed over" pump, JRE Stage III plate, AFC spring kit, BD gov. spring kit REMOVED!!, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil& transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
Hey Brian,
Glad to hear that you finally got what you are looking for, sorry the Spring kit didn't work for you as well as it has for others, send it back to me and I will refund you.
Been waiting to hear what you where doing.
Ted Jannetty
Ted Jannetty, Owner President jannettyracing.com
97 3500 4x4 club cab 5spd. RED, JRE stage 3 power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc, Horton fan clutch
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
99 Ski-Doo 800 Formula III
99 Honda Forman 450 ES
2001 Ski-Doo MXZ 800 X
2000 TransAm Ram Air WS6
Brian:
I am SO GLAD to hear you got your truck
running the way you want it to!! Now you
know why "Koa Man" and myself "love
those 370'S" so much, huh?
I felt the exact same way you did when
"Scheid Diesel" finished mine in Sept.
at the Rally. It really makes a BIG
difference when you have a shop like
Dave's or Scheid that "really cares
about what the customer wants" and also
lets you "participate" in the modifi-
cation process so you can understand
what is really going on inside these
5. 9 engines!
I'm really happy for you and I know
when "Koa Man" reads this he will be
too.
Take care Brian!
John_P.
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods, 370 injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit, Pro-Torque Converter, BD Valve Body, Sendel 16" Alum Wheels w/ 33" BFGs
Can you elaborate more on the governor spring kit problem? I am planning to install the kit into my ride tomorrow. I pulls hard now with the mods already done but falls down at hi rpm. I bought the kit to get more rpm but don't want to give up low end or mid range because that where I'll be much of the time. I have the 6 spring kit for the 180 California pump. I have run the high idle set screw in nearly all the way which allows 3400 rpm now. It will pull redline in high gear with some pedal left at 110 mph before spring kit mod.
98 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, Governor "Modified", Walker Muffler, SS Tube Steps, Fifth Whl Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho RS5000 Steering Stabilizer
More info on that Gov. kit! Why did it not work?
Ted? Any thoughts?
Bigkavr,
What is your top rpm now?
Keep us posted on mileage please!!
WANTED: Wrecked Dodges. 1997 Cummins Dodge 4x4 Bombed & Amsoiled
Member of TDR,LIC-ROC,GLTDR,NRA www.awdist.com
Brian, glad to hear about your great time at Dave's. I wish we could have got together. I hope Rick didn't set you up higher than me #ad
just kidding.
Eric
GLTDR
